RE: Right thrust and 3D
As is often the case with aerodynamics there is no definite answer. Especially not when it comes to compromise solutions such as adjustments of the engine thrust line.
I make decisions about the thrust line only after flying the aircraft several times. If I find that I have to apply right rudder more often than not in different maneuvers I add some right thrust to the engine. For me the correct amount of right thrust is what minimizes the need for right rudder corrections during a typical flight of the aircraft. Typically I seem to end up with 1-2 degrees of right thrust for my 3D aircraft (.40-1.2 cu.in. size).
