RCU Forums - View Single Post - New CMP Cessna 182 .52 size
Old 09-02-2008 | 02:11 PM
  #202
damon
Default RE: New CMP Cessna 182 .52 size
ORIGINAL: DSTIEBS
Damon: I won't get this plane finished until spring. I am taking my time to do it right with more heavy duty parts than came with the Cessna 182 model .50. I still don't know if the OS FS 81-a will fit the cowl so I have not bought the engine yet. I'll have to do the measuring from the OS spects and center of the fuselage and add a extra pushrod to the rudder. I will post the throws but don't know when. Thanks.
I am using an OS FL 70 four stroke. The rocker cover sits well out of the cowl & the cowl has to be trimmed to accomodate some of the cooling fins on the top of the engine. It doesn't look bad, but I assume an 80 would require more trimming of the cowl. Thanks for the throws when you get them.
