RCU Forums - View Single Post - Advice on Repair of Sig LT40
Old 09-02-2008 | 08:07 PM
TedMo
Default RE: Advice on Repair of Sig LT40
Since you already have satisfactory reply on fin and cheeks I will only comment on the nose wheel problem. First you MUST file a flat on the gear where the set screw contacts it. This will prevent gear from rotating. Only other thing is to put a drop of thread lock on set screw then tighten very well. I see no reason why you're not able to get allen wrench on it to tighten.
