RCU Forums - View Single Post - Advice on Repair of Sig LT40
Old 09-02-2008 | 09:06 PM
Charlie P.'s Avatar
Charlie P.
Default RE: Advice on Repair of Sig LT40
I can not tighten the screw that holds the nose gear aligned enough to keep it from coming loose every landing. Is there anything I can do improve the nose gear?
Yes. Take a flat file or Dremel and grind a flat spot in the strut where the set screw contacts. Then add some lock-tite and tighten it down.
