RCU Forums - View Single Post - front wheel question..... what is this?
Old 09-03-2008 | 12:39 AM
OzMo's Avatar
OzMo
Default RE: front wheel question..... what is this?
a piece of sulivan golden rod( flexable plastic rod in a plastic tube) or similar fastened to the rudder servo arm's oposite side. the arm on the nose wheel gives you the option of either side....depends on your rudder servo. this way the nose wheel steer s while on the ground and the rudder for in the air all on the same srevo.
