ORIGINAL: XTOL
Looks very good! I probably had my wing tips a little more
rounded than you have yours but not by much. Smooth contours
is the design philosophy of this plane.
When you are sanding the LE of the wing remember the contour
of the LE is different at the root than at the tip. Use the supplied
template off the plans and a long sanding bar.
Mike,
Thanks for the input.
Yes, I am using the LE root and tip templates for shaping the LE. Those long GP sanding bars are appropriated for the task.
Pedro
