RCU Forums - View Single Post - Big block conversion
Old 09-03-2008 | 03:05 PM
hooleydog
My Feedback: (24)
Default RE: Big block conversion
Hi, Guys well I have finnished the big block conversion and it was really easy to to, but I did have a problem IE: the back wheel was rubbing against the Manifold, so for now I had to put a spacer on the axial so the wheel is out a bit more so it'll clear the Manifold. I removed the metal tape and J.B Welded 2 peices of aluminum and riveted them to the chassie.
However the shocks are too soft for the extra weight and they will bottom out. Anyway to fix that??
Oh I was able to custom fit a 100cc tank instead of the 75cc one (looks good eh??).
ID:	1025534   Click image for larger version
ID:	1025535   Click image for larger version
ID:	1025536   Click image for larger version
ID:	1025537   Click image for larger version
