RCU Forums - View Single Post - Installing wiring within a foam wing to outboard ailerons
Old 09-03-2008 | 05:35 PM
Gray Beard
My Feedback: (-1)
Default RE: Installing wiring within a foam wing to outboard ailerons
I have the copper tubing too and do the same thing except I heat the tube very hot with A torch, it melts the foam as it goes, A perfect lead tube. I cut my servo leads and solder in new wire to extend my servo leads. I have had the extensions get dirty and slow down servo action unless you remove the leads and clean them every year at least. I solder and forget. It's A lazy thing!!
