RE: Dirty Birdy Build Thread
Thanks for the photos BERUSTY. Your plane is looking good.
Ed,
I fullly understand your thinking and appreciate your post. I had already epoxied the firewall in place though so this one is going to be built stock. Like you said, it should fly great.
The attached photos show the tank top block that's been relieved a bit on the inside as per the plans. - I guess for fuel tank clearance.
I've got the rear top block glued in place.
Next will be the front top block and finishing out the nose. I'm going to save installing the rear bottom block until I get the pushrods in place.
Cutting the slots in the side of the fuse for the stab is going to take some time.
