RCU Forums - View Single Post - front wheel question..... what is this?
Old 09-04-2008 | 12:00 AM
5focus
Default RE: front wheel question..... what is this?
The steering wheel appears to be turned 180 degrees. The coil on the strut should be facing toward the rear and there should be a flat spot on the strut to locate the proper position of the steering arm. Check it out.
