RCU Forums - View Single Post - Looking for a method....
Old 05-21-2003 | 09:37 PM
KadetBuilder
Default Looking for a method....
Originally posted by MinnFlyer
Just cut the leads to the battery and solder an extension in between the cuts. Then cut a hatch in the bottom, install the battery, and re-seal the hole with an Ultracote patch. That way, when you need to get inside again, just heat it and peal it off. I've done it many times.
I like that idea! Easier than trying to make a balsa hatch cover!
