MHZ Gecko setup ? ? ? HELP !
She came in the mail today & need help setting it up.
Can anyone give me the dimensions you used?
Placement of the motor
How to mount it to the hull?
How far is the drive shaft sticking out the back?
Can the motor handle 8 cells? I've bought two 1100 2/3A packs split with four each side. I hope it will, cause if not, I'll be unsoldering.
What size steering servo? Can I use my standard?
Dang guys, I need some input here or I'll pull my hair out. Do a search on the net & you (I at least) get nothing.
Regards,
Jamie
GIVE ME SOME INPUT !!!! (please)
