RCU Forums - View Single Post - Setting correct surface throws
Old 09-04-2008 | 01:56 PM
TexasAirBoss's Avatar
TexasAirBoss
My Feedback: (22)
Default RE: Setting correct surface throws
I believe the most accurate measurements are actually taken using satellites.
Initial set up is used with a ruler and the instruction's recommended throws. Then you fly. Then you make tiny adjustments using your Xmitter until the plane performs and feels the way you like. That changes from person to person. Your throws will be different from everyone elses. So excrutiatingly accurate initial values are not needed.
