RCU Forums - View Single Post - OS 70,Second Request
Old 05-27-2003 | 05:48 PM
Bax
Default OS 70,Second Request
To remove the piston, remove the cylinder head, slide the liner up a bit to expose the wrist pin in the hole that's in the back of the crankcase. Extract the wrist pin through the hole, and then slide the liner and piston out of the engine. Use the reverse procedure to reinstall the piston.
