RCU Forums - View Single Post - OS 70,Second Request
Old 05-28-2003 | 02:30 PM
Bax
Default OS 70,Second Request
Dave,
Sometimes it can be tapped out, other times, we use a small screw extractor inside the wrist pin. It grips and we then pull out the pin.
If it's a bit stuck, a bit of heat from a heat gun can help loosen it.
If the wrist pin is really stuck, due to burned-on fuel residues, sometimes the only solution is to cut the con rod. You can minimize chips by drilling a series of holes in the rod and then using nippers to cut through the bits left between the holes.
Cutting the rod is done only aa a last-ditch effort. Then the wrist pin can be driven out of the piston.
