RCU Forums - View Single Post - 6v Battery???
Thread: 6v Battery???
Old 05-22-2003 | 10:24 AM
Luke 3D
Default 6v Battery???
A glider champion told me that Nmihs were a bad idea, because they have a significantly larger voltage drop when placed under load when compeard to Nicads. The problem with this is that when you do a snap roll or lower the flaps, the current drain from the high performance servos put a large load on the battery........ the voltage supply goes down so much that the reciever goes into failsafe or it goes out of range- hence broken model.
I do not know wether this problem occurs at 6 volts though.
Maybe it doesn't, but im sticking with good old nicads.
Luke
