RE: Another RC10GT build thread
The only pbs you will have is that the manifold will not go over the pull start ,it should pass very close to the back plate of the 18TZ so if you have a pull start there will be no more space for the manifold and even if you manage to put that engine with that manifold it will then not fit under the body .here is a pic of mine with the 18 TZ and a THS inline pipe .
