RE: Installing wiring within a foam wing to outboard ailerons
The only thing I shall add to the suggestions given is: after making the connection to servo lead with extension wrap both connectors with masking tape to prevent them from coming apart. This will also permit them to be withdrawn without scraping the foam tunnel, if and when you wish to do so.
