RCU Forums - View Single Post - Servo doesn't fully return to center
Old 09-05-2008 | 04:54 PM
Frozenshade
Default RE: Servo doesn't fully return to center
ORIGINAL: mabuecker
I assume you have noticed this when buggy is sitting still ... this is common in a sitting still situation although when it is running (if its what I'm refering to-sitting still) it will return to center ... if the servo has been centered and all steering components are in working order it will track straight in a running situation yet sitting still might not return to center one direction or the other ... I have a truggy that done this and all components were new as well as servo and it kept off centering when sitting still , when I drove it the thing was right on ...
You might be right. I'll look into that. The only reason I was curious about it is because it only does it for one direction.
