RCU Forums - View Single Post - will this battery work
Old 09-05-2008 | 07:27 PM
K_B's Avatar
K_B
Default RE: will this battery work
From Tower Hobbies description for that charger:
**This charges at a 5A rate and is NOT recommended for charging NiMH batteries. The charge rate is not adjustable on this model.**
It's best to use a peak charger.
http://www3.towerhobbies.com/cgi-bin...&I=LXCLD5&P=ML
That battery is also meant for the 5B so it has that Tamiya plug on it. I'm curious as to whether that battery is actually made of 2/3A cells or the bigger 4/5C cells which are bigger and won't fit in the radio box...
