RE: New CMP Cessna 182 .52 size
Zener please check your PM's !!
Also, sounds like not enough speed and the classic tip stall. You need to use your rudder when this happens, ailerons will only make the situation worse. Good luck on your next try !! I have one on the way, probably going to put it on floats, and it will be electric powered
