ORIGINAL: Missileman
Throttle causing interference due to metal on metal contact will only cause a problem with the engine running, if your engine is not running this is not your issue.
I will dissagree. If the throttle arm is metal and the clevis is metal, just operating the trottle (with the engine not running) can cause interference.
