RCU Forums - View Single Post - AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast!
Old 09-07-2008 | 06:14 AM
  #3307
toddlupton
Default RE: AquaCraft U-18 Miss Vegas Hydro Thread_Make it Fast!
also on that pull start, #1 when you remove it use a small screwdriver to make sure the whole thing comes off the shaft as an assembly. You don't want the spring to come apart. also I use the flex shaft grease on the shaft and oneway bearing. makes it last much longer. metal shaft and metal one way bearing and no lubrication at 28,000 rpm will only last so long.
