RCU Forums - View Single Post - Warning! Mad Scientist At Work!!!
Old 09-07-2008 | 08:43 AM
CGRetired's Avatar
CGRetired
Default RE: Warning! Mad Scientist At Work!!!
I had an OS 50 SF on mine and it flew just fine. This plane will probably take up to something like a 55 AX without any problems. Just prop it correctly and it should be fine. It sounds like the engines are the same weight, so the CG should be ok.. just make a quick check before flying it.
CGr
