RCU Forums - View Single Post - Anyone tried worldmodels TAMEcat ?
Old 09-07-2008 | 10:11 PM
simitar1
My Feedback: (60)
Default RE: Anyone tried worldmodels TAMEcat ?
It measures 8.125 inches using a level and square. While you could gain or loose a little vertical, depending on the exact position of the collar on the nose gear, 8 inches is what you have, centerline to ground.
If you are hauling a 60 Stik, which probably weighes about 8oz. more than the Cat, the performance should be impressive.
