RCU Forums - View Single Post - UAT not staying full..
Old 09-07-2008 | 10:22 PM
  #45
Boomerang1's Avatar
Boomerang1
Default RE: UAT not staying full..
I am absolutly pulling my hair out with a UAT problem. My first 3 flights on my new lightning have all ended in dead sticks. I am using a Artes Rhino, 2 Comp arf tanks, and a BVM UAT. I am getting air pulled into the UAT which eventually unprimes the fuel pump and the turbine quits. I have done everything imaginable to fix this problem. I have double safety wired every connection, replace all fuel lines, and I still get Air bubbles. I have tried 4 UAT tanks and still get the same problem. I have even extensively tested each UAT by taking it out hooking the fuel pump side to my Jersey fueler, dropped a new line straight into the jersey tank completely submerged, safety wired all connections, pull from the UAT, and I still get small air bubbles in the UAT. I am completely out of ideas on how to solve this Frustrating problem. Does anyone have any idea what is happening?
Buzz
http://www.rcuniverse.com/forum/m_7914946/tm.htm
http://www.rcuniverse.com/forum/m_7798607/tm.htm
Check these two threads out. Seems restriction by the filter/clunk is the culprit. - John.
