ORIGINAL: Barry Cazier
It doesn't really take any special equipment to install two servos per wing. It can be programed with your radio or you can use "Y" harness and plug into one channel of the radio. Really not that hard to do. And...with this big of a wing (keep in mind, nobody has this much wing area in the 50 cc class) it probably needs the extra servo per wing.
Again, you don't need matchboxes or ANY special equipment to run a (4) servo wing set up. Thanks
BArry
I would have to go the Y harness route since I only have the DX-7.
But what if the 2 servos are not perfectly matched ? I was planning to use 5645's.
I was told that even 2 of the same servo are not always exactly the same. Deadband or speed may not be exactly the same. Would that not cause the 2 servos to fight each other?
Or am I just worrying too much about it ??
I suppose I could invest in the Hitec servo prgrammer. It would always be helpful in the future as well.
