RE: Ryobi tuning help
Be darn sure the Pulse Hole on the carb lines up and no leaks around it. Since you flipped the carb. Had the same issue happen to me but on a Fuji Engine.
If all is correct-Sounds like you have to adjust needles-High end first, then low. It may need to be open bore than normal or just the opposite. Very tricky when larger carbs are used. Is the Venturi size #28 ??
