RCU Forums - View Single Post - HELP WITH RETRACTS INSTALLATION
Old 09-08-2008 | 01:50 PM
Campgems
Default RE: HELP WITH RETRACTS INSTALLATION
Salman, measure the throw of the retracts, end to end. That is the diameter of the attachemnt points on the servo. You may be able to go just shy of end to end movement and still keep things locked tight in the retract, but not bottoming out on travel. As there is no end point adjustments, you have to hit the throw exactly with mechanical adjustments.
Don
