RE: Help with 31cc Ryobi conversion
too much air getting past the throttle butterfly, are there any holes in the plate? if so, solder them shut one at a time until you get the idle you want, and if there's a little hump of material removed down by those holes in the carb bore, try soldering some of that down as a last resort.
is this carb the stock or larger than stock?
