RCU Forums - View Single Post - Right thrust and 3D
Old 09-08-2008 | 09:10 PM
  #42
3D_Junkie
Default RE: Right thrust and 3D
The effect that you guys are talking about with the warbirds (or any single engine aircraft) is from P-factor not slipstream effects on the rudder.
The p-factor is caused by the difference in angle of attack between the ascending and descending blades of a rotating propeller blade. Specifically, in a "nose-up" situation where the propeller disk is inclined to the flight path, the descending blade has a higher angle of attack relative to the ascending blade. The propeller blade with the higher angle of attack will provide more force.
P-Factor does not really come into play during 3-D flight since the forward motions are small and there is really not a difference in the angle-of-attack of the propeller during flight.
I could be wrong though, as I am sure someone will point out.
