RCU Forums - View Single Post - Sportmaster
Thread: Sportmaster
Old 09-08-2008 | 11:25 PM
jrbmoto
Default RE: Sportmaster
I had modify the fuse quite a bit to except the OS .91 Surpass and the fuse mounted main gear. I moved the firewall aft 3/8" (this required a new taller firewall) and I had to build up the bottom of the fuse sides to accomidate the landing gear mounting block. I cut the "cheeks' off of the sides so that I could build up the cowling from balsa blocks similar to a Super Sportster.
ID:	1029491   Click image for larger version
ID:	1029492   Click image for larger version
