RCU Forums - View Single Post - Building the Seduction Freestyle - more tips added.
Old 05-19-2002 | 02:00 PM
  #56
kris1
Default Building the Seduction Freestyle - more tips added.
Mine was bought, as was Ricks, ATS in UK offering. With a few mods mine came out at 4.5lbs. Ricks was about 4 3/4 lbs, but he did add quite a bit more timber and loads of profilm.
As you may be able to see the cowl is broken. This was after I smashed it. As you see it now is after the rebuild and yes 4.5 lbs is it weight now. The fuz was snapped in half from the t.e. of the wing. The balsa was glued back together using cyno and the fuz was braced with 1/16 ply on both sides. If you are building one I would suggest this as a stanadrd mod as ther is very little timber at this point. The cause of the Accident, I was using carbon push rods, the rod for the rudder came loose and caused the rudder to shift about 40 degrees over. If I had more hight I would have sorted out but I only had 40 foot or so... If you are using carbon control links be warned....
