RE: Help with 31cc Ryobi conversion
A few months back some buddies at the field were having idle problems with a G-62. The end result turned out to be a crack in the plastic carb spacer. They replaced the carb and plastic spacer from another G-62 and fixed it. You couldnt see the crack until you had the spacer off the engine.
Edwin
