RCU Forums - View Single Post - Help with 31cc Ryobi conversion
Old 09-09-2008 | 08:12 PM
av8tor1977's Avatar
av8tor1977
Default RE: Help with 31cc Ryobi conversion
The last time I had this happen, it was the carb butterfly being worn and allowing too much air to pass when closed. Hold the carb up to a light, and when the butterfly is closed, you should not see any light showing through the carb. This can also happen if the butterfly isn't aligned perfectly when installed.
Good luck,
AV8TOR
