ELAPOR FOAM with EPOXY?
i bought the multiplex minimag and it keeps stressing how medium CA and hot glue is the only recommended glue to use on it.
here's what it says about epoxy:
"Epoxy produces what initially appears to be a sound joint, but the bond is only superficial, and the hard resin breaks away from the parts under load."
can anyone confirm this? ive seen other threads about elapor foam and ppl say many different glues produce excellent results, including epoxy
