RCU Forums - View Single Post - What is the formula to figure your scale?
Old 09-10-2008 | 08:41 AM
bruce88123
Default RE: What is the formula to figure your scale?
Divide actual aircraft dimension into model dimension and result will be percentage. Example: Real plane has 20 ft wing and model has 2 ft wing. Be sure to use same units feet or inches. 20 divided into 2 = .1 or 10 percent. It's a simple ratio.
