need help-Piston Ring orientation
Dang, I took out both rings from my SPE26 to replace with a Bowman ring.Thing is I didn't notice the ring orientation while removing the rings. The ring ends are tapered and pointed on one edge.Should assembly be the pointed edge of the ring being on top nearest the piston crown or vice versa? Thanks
