RE: *Airtronics RD8000 2.4 GHz*
i would think that velcro would give you some vibration isolation if that is all that is used. if you follow up the velco with a zip tie around the whole lot, then you have just increased your vibration.
now is velcro alone better that latex foam and a zip tie? dunno.. i do know that i use velcro only to attach some batteries to some of my smaller planes, and the battery is heavy enough to let go in a hefty crash. maybe the rx is light enough, the velcro will not let go. i guess time will tell.
as usual i have shared some electrons with out imparting any wisdom at all. someone should take this keyboard away from me!!
