RE: ELAPOR FOAM with EPOXY?
I have a striker the RX went bad 2nd flight
and the T28 dumb thumbs first flight and A limbo contest I put her into the pole
I used 5 minute epoxy the striker was in 1/2 glue it together never had a problem since
the T28 first flight ripped the wing off glued her back on and later when I hit the limbo pole , cartwheel and ripped the wing off again where I had glued had held another part ripped witch I was glad to see that
may want to use 15 min epoxy or 30 min epoxy to get things in place If you go this route
