RE: ELAPOR FOAM with EPOXY?
Parkzone says their foam is Depron and characterizes it to a higher density styrene foam. They also say that it takes the glues that "normal styrene" foam takes.
Multiplex says their foam is Elapor and that it isn't like the more common styrene foam. And they say that epoxy won't give a lasting glue joint.
