RE: Flyeagle F18F
All - I just talked to JamesI live 45mins away...
Anyways, he said they build all F-18s very strong but if you are going to use a 36 pounder, then they build it a bit lighter... So, if you told FEJ what turbine you will be using, then they build it accordingly...
I suggest to those of you who have ordered but the plane has not been built yet, if you even think you will go above 36lb thrust, to contact them and let them know. But if you will remain 36 or less, then leave as it, for it will be too heavy. Just a my thoughtsthe move is yours...
Mr DJ
