RE: Finishing a Cajun R/C Tiger Tail IV
Well got all moved so to speak and got down to the finish details....I had thought I was ready to apply the final coat of White Klass Kote 2 part Epoxy primer when I found I was out of the primer AND I had ' lost' my TTIV rudder during the moving process, so built and glassed another- Then installed elevator and rudder linkage, using a D.H.S. coated kevlar pull pull arangement on Rudder and a Central Hobbies C.F. push rod with Titanium fittings, with a B.B. fuziwhatzit on the Elevator and of course the Titanium threaded rod screwed into a Dubro 4-40 swivel ball link, on on the elevator servo end of the Central Hobbies C.F. push rod kit. Finally while waiting for good out of doors painting conditions went ahead and re inforced the bottom wing center section out just past the aileron servo cut out and retract bay and mounting area,all needing reinforcement as I found with my first Tiger Tail IV,so a little extra sanding and finish priming is now in order and then..
