RE: *Airtronics RD8000 2.4 GHz*
The results I reported above are with the battery not installed in the radio accept during the few seconds to get the numbers. But I had previously established that the rapid decay was not associated with being installed in the radio. Also I had previously established before running this test that it was not associated with the wall wart, or rapid charging. It is the battery and may be associated with changes in battery chemistry to help the environment but I don't know nor pretend too. Just make sure your battery is freshly charged 12 hrs before going and doing a full day of pylon racing. Good enough as long as you are aware.
Denis
