RCU Forums - View Single Post - pull pull accuracy
Old 09-11-2008 | 02:59 AM
Rendegade
Default RE: pull pull accuracy
With the radio on, can you wiggle the rudder? if so you have a slop issue.
Check to see how much movement is in the servo (some have centering issues), and tighten your cables, they should give a satisfying "tong!" when plucked.
