RCU Forums - View Single Post - pull pull accuracy
Old 09-11-2008 | 03:47 AM
selnekav
Default RE: pull pull accuracy
Hi,
both servo arm and horn length are the same ( arount 20 -25 mm on each side ), the servo centring is also ok. about the cable tension as i didn't want to put to much stress on the servo shaft i set it so there will need of small force in order to connect the servo arm to the servo.
