RCU Forums - View Single Post - pull pull accuracy
Old 09-11-2008 | 08:55 AM
selnekav
Default RE: pull pull accuracy
thanks alot
i think i will take the following steps :
1) Remove the cables from the plan and check that teh length is equal. also i will check the rudder horns in both side to make sure all measures are the same.
2) Reassmble the pull pull and check the centring
i will update.
