RE: pull pull accuracy
You don't really need to dissassemble,....just deflect the rudder in both directions and check the tension on the opposite side you deflect the rudder. Tighten the slack side or the side opposite the direction you have moved the rudder. Do this in small adjustments,...and the rudder will eventually center,...you may have to change your trim a tad to get it to bounce back and center in both directions. If you have any sub-trim in the radio for rudder,..remove it and put it bach to zero,..make sure your trim is centered before you start making any large adjustments. For sure check, the control hardware at the rudder.[8D]
Good luck,
Bill Holsten
Dist2
