ORIGINAL: TedMo
I'm not really sure what you're trying to do using a y harness? To connect 2 packs in parallel You should be using a parellel deans connector which will then plug into your ESC.
Because I didn't know about the parallel connector. Thanks for the tip. I found this link
http://www.google.com/products?sourc...num=1&ct=title where they have both parallel connectors, and Y harneses.
I am still a little wary of having a ''hot'' male plug dangling about. even for just a couple of seconds. Brain farts often happen in milliseconds.
