RE: Sparks from spur
The upgraded brace fits fine, it's exactly the same size. I wouldn't worry about the sparks, eventually the spur will make a tiny bit of clearance for itself and it should be fine. If you experience very worn clutches, or lagging acceleration/speed, then either sand some material off, or grind a bit with a dremel.
